Help with model number and year
Asnyder19
So I have a force 125. The guy I bought it from said it was a 89 but I'm having my doubts. It's in the shop right now so these pictures aren't the best and I'll get more tomorrow. The model number tag is faded and unreadable. Can anyone tell me maybe what year and model number? Trying to order an impeller repair kit. Thanks!
jerryjerry05
From the color on the hood it looks like an 89.
Under the bottom carb and under the power packs and coils,
there's a foundry stamp.
Sometimes the starter has a date? unless it's been changed.
The center of the foundry stamp has the year it was made.
The impeller 803630T
is for 89 and older.
Remove the drive and check the impeller housing.
If it has a stainless insert, it needs a 89984T3 that fits 90-95
The actual model # isn't needed unless you need a specific part.
The model#s were given if ANY change was implemented.
Even a screw change or hose clamp change warranted a new model#
Asnyder19
Thanks Jerry, do you know if anyone makes a kit with the gaskets and everything? There is a few on Amazon that say they will work but each one looks different.
jerryjerry05
[h=3]The kit is about 140 OEM
These parts are for the old style.
The new style has the stainless insert in the housing.
That kit is $80 OEM
Old style
IMPELLER 803630T[/h] [h=3][/h] [h=3]GASKET F523031[/h] [h=3][/h] [h=3]PLATE F523562[/h] +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
These parts are for the newer style
WATER PUMP KIT
FK1202-1
Gasket F694830
Impeller 803630T
[h=3]GASKET F694031[/h] [h=3]GASKET: F523031[/h] [h=3]PLATE: F523562[/h] [h=3]INSERT F694564-1[/h] [h=3][/h] [h=3][/h] [h=3][/h]
[h=3][/h]
