Help With Motor Mounts Pics!!!
betayv
HI THERE MY BOAT IS A 1978 CRUISER BARNEGAT 22FT LOOK THE WAY THE MOTOR MOUNTS ARE SET SHOULD I REPLACE THE BASE? ANY ADVISE THANKS.
THANKS...
legoman67
Re: Help With Motor Mounts Pics!!!
looks like it works, sure its not pretty, but if it aint broke dont fix it. Its a huge job to fix and for what gain?
the only thing that i dont like is that bolt on the angle, looks like its loose.
it does make me wonder why it is like that. can you give us some background?
tashasdaddy
looks to me there was an alignment problem. fixed the shade tree way. i would check all the mounts. also could be the engines or mounts were changed in the last 31 years.
Ayuh,... Not too pretty, but entirely Functional,.....
betayv
hi there and thanks again, this was like that when I bought the boat last year and the bolts look loose but they good (NOT loose) The guy who I bought the boat he said that this wasnt the engine that came with the boat so I was thinking that they fixed like that due to aligment But Im worried about the wood getting rotten is good for now but for how long? thanks again all you guys.
tashasdaddy
i would atleast get a coat of paint of that raw wood. as long as water stays away it should be fine. bilge pump.
betayv
ok thanks I will to some painting on it and yes I have two bilge pumps 1 850 gal/hour and 2 1200 gal/hour.
proshadetree
I would check alignment 1 of the nuts in the pictures looks like it has backed off.Polly or paint to slow the rot.When it fails fix it right.
lmannyr
Master Chief Petty Officer
I doubt they properly attached the raw wood to the stringer. Keep the bilge dry.
Good Luck.
Revenge
What is the proper method to space the motor mount brackets up?
Thanks in advance.
legoman67
usually you are only talking a 1/4 of an inch or so when adjusting the engine, and you just adjust the bolts on that shaft mounted to the wood. but they dont have enough travel to lift an engine that far. What he did is the correct way, but he didnt spend any time making it look nice or protecting the wood.:p
sturdavj
You may want to double check the wiring in the photo background.
The red wire (battery cable?) looks like it might use a wire brushing and a thin covering of dielectric grease applied once the connector is tighten down.
The mount looks like it will do the job, but if it's going to be on your mind you may want to make the recommended fixes so that you can enjoy your boat.
EAVES
That is a aweful repair and i would fix it properly if not at least unbolt the mounts and lift engine enough to brush some resin on it but its your call and i doubt the lag bolts are long enough to go through all the extra wood and if not then the engine will move around some and eventually take out the gimble bearing
