Help with my 1979 Evinrude 200HP
I can start it run WOT for about a min. then it boggs down and I can pull it back to neutral then run it up to about 2500 rpm and it runs fine but if I go above that it starts to bogg out?? if I pump the bulb it helps but the ball it hard and you have to pump it really fast or it doesn't help.<br />also when it was acting up I was just running it blow the 2500 rpm mark which it runs fine but I punched it and ran WOT and it ran fine until I slowed down again then it wouldn't run above 2500rpm again??<br />is it fule pumps? this motor has two?<br />I changed power packs and carbs were rebuilt last year.<br />any Seggestions?<br />thanks<br />Derek
Re: Help with my 1979 Evinrude 200HP
also did compression test 1-114,2-115,3-111,<br />4-121,5-113,6-111<br />but number 1 cyl. a bit of Oil around the outside of the plug?
