Help with Nav Lights and wiring
wlaur
I recently picked up a 1970 Larson Tri Hull. Nav Lights (Bow-red/green) and stern pole light do not work. The wiring under the dash looks like spaghetti tossed in a big bowl. There is a panel that is bolted to the dash. The left button on this panel I suspect is the horn. The next switch to the right on the panel is a toggle switch that illuminates the tachometer, then there is a cigarette lighter. The horn does not work; however the toggle switch to the right does illuminate the tach and the cigarette lighter works. There is no ground coming off of the cigarette lighter, which is why I suspect that the panel that these switches are on serves as the ground. The 2 way switch to the right of the steering wheel is the nav light switch. It has three white wires coming into it. I replaced switch which did nothing. Again, there are different colored wires that are spliced into each other and it is not an easy wiring schematic to follow. I am going to try to cut the wires at the base of the lights (bow and stern) and see if I have power after connecting to another power source. Any ideas on what I'm dealing with since neither bow or stern light works. I wish I could have a more simplified wiring harness where I can just plug in the leads. I suspect they did not have that luxury in the early 70's. Again, I need confirmation that the panel that the switches are on serves as a ground and how best can I figure out whats going on with the bow and stern lights. There is a battery switch and seems like all comes off the ground/negative of the battery.
Silvertip
Re: Help with Nav Lights and wiring
If one of the lights doesn't work that typically says the problem is in that light or the circuit leading to it. If none of them work, that says either the fuse protecting the circuit is blown, the switch is bad, +12 volts into the switch is missing, the lights are not grounded, or 12 volts out of the switch is missing.
