Help with omc cobra oudrive.
todds59
I have a 89 smokercraft with a 5.0 omc and cobra drive. The gears were out of the lower unit when I bought it. I had a guy rebuild it and It was fine the first 2 times on the water. The third time was in the river and stopped for a minute, went to put it into gear and heard outdrive making noise. Shut it down, took home and the gears were out again. Now I need some advice. Don' t want to sell the boat cause my family loves the water. Is there a cheaper route than paying 2500 to 5000 for a new rebuilt outdrive.
Re: Help with omc cobra oudrive.
Nope,.... Not really....
Unless you do your own Wrench turning,.... Then you could cut the Labor out of that #.....
sea wolf
Uh, who did the rebuild? Was it one of your buddies or did you take it to a shop? Somebody obviously screwed up for the outdrive to be toast after only 2 times out.
