Help with parts
OleChry
I need to find a few parts that seem impossiable to find. any help would be appricated
1975 chry outboard 25 hp 254ha
1: Shift adjustment nut
2: the two clamps that hold the throttle and shift cables in place under hood of motor
Any help would be awesome or if u have / know someone who is selling these parts id be more that happy to buy them ive rebuilt this entire motor from power head to lower unit and this is all I need to get her back in the water.
thanks again.
OleChry
Re: Help with parts
ill shoot em an email.
are they universal from any other motors I may be able to use? any idea on a part number to where I can find a adjustment nut for the shift linkage bar?
Frank Acampora
Re: Help with parts
The adjusting nut is used on many other sizes of Chrysler and early Force--20,25, 35, 50, 55. The clamps are universal to again some specific Chrysler engines ( smaller sizes meant to be used as tiller and made to be converted to remote like the 20, 25, and 35), and the control box. One cable is secured inside the control box with that clamp. If you have a junk engine or two in the larger size, you remove the cable clamp from the timing tower and shift link. You can cut off the pivot tabs and drill a hole in that side. Then it will be usable.
