I bought a 1994 Bayliner 2052 Capri with Mercruiser 4.3L (190HP). Today I hit a partially submerged log and damaged my prop. The only info stamped on the prop is BISHOP and HH53245, there are no numbers stamped on the inside of the hub or anywhere else. Either the numbers are worn off or it's a no name prop. Can you help me ID the prop or what size diameter and pitch was standard for this boat and motor? Thanks in advance.
JoeB13
JoeB13
