New to this stuff but just bought a 1984 Mark Twain 19' Open Bow - great looking and somewhat unique boat imo. I'm learning here as I go so be patient. I now know I should learn the proper RPM range for my engine. Here are the specs.
Boat: 19' V Hull, open bow, about 2500lbs - a fairly heavy 19 footer BR from what I've seen. I don't know enough about the engine yet but here's what I think i know: I/O 1984 5.0L Mercruiser with alpha drive. (305 Chevy Small block i think) 2bbl. I was told it's 200HP and has a 1.65/1 gear ratio (rebuilt recently, used parts i assume).
Any educated guesses on what I should look for in WOT RPMs and Top Speed? It currently has a 19' pitch Aluminun 3-blade prop (haven't seen it's condition as it's been docked).
I'll be testing it a bit tomorrow (Thurs.) so i want to know what to look for. I already plan on adding some Smart Tabs to keep the bow down a bit when pulling skiiers and tubers. Also looking for lower comfortable cruising speeds. Top end less important, but I'd like to get close to where it "should be".
Thanks.
Thanks.
