Re: Help with repairing a hole in fiberglass hull
You don't have to rip up the floor to repair it. You do have to grind the skeevy old exposed fibers away. You will want to grind until you see clean fibers in resin. How you repair it depends on if you are concerned about appearance or not. I had a gash on my hull that I repaired by grinding until clean fibers, then dishing out to about 2 inches out all the way around. I mixed epoxy to the consistency of peanut butter and filled the gash, and then layed in epoxy saturated cloth from small pieces increasing each piece size to fill in the dished area. The end result was flat and even with the rest of the hull. I did not care about cosmetics, so I left it at that. If cosmetics are a concern then you have to fair the repair with a marine specific filler, etc. Another option is to do the repair and then install a keel guard. It will conceal the repair and protect the area from further damage. Good luck...
