Help with San Juan cooling kit choice (v111, v112) for 4.3GIPBYCCE 1998
Radon17
Hi, I'm want to convert from raw cooling to FWC. Confused about which San Juan kit, V112 says - 1994-2007, GL Cools Block Only. Adds 3? the Front of the Engine. Specify if 2004 & UP. Fits V-Belts Only. Carb/EFI Applications. V111 says - 1997-2007, ?Off Engine Mount? Due to Fuel Pump & Alternator Locations. Adds 1 ?? to bottom of engine. Cools Bock Only. Confusing, anyone have this engine with a SJ cooling kit or knowledge of SJ cooling kits? Thanks!
Re: Help with San Juan cooling kit choice (v111, v112) for 4.3GIPBYCCE 1998
Ayuh,.... If yer motor's been run in the brine since '98, it's Way to late for a heat exchanger,...
Radon17
No, it has been in fresh water its entire life, never ever been in the ocean. I took the risers off to inspect them and they looked new inside.
ciscokidd
If its a V Belt motor then you need the V112, you can call Brad direct at San Juan. I live in BC and sent him pics of my 2000 Doral 250SE which has 98 5.7GS Penta motor in it that was run in fresh water for about 5 mths a season then winter stored until I bought the boat last Nov. I had the V112 1/2 system FWC installed and I sent him pics to confirm as I had selected the wrong kit, Brad is the owner and San Juan is in WA not far from me, I found them very helpful and accomodating to do business with. Good luck
Radon17
Thank you, I sent Brad my pictures and he helped me out, great service. Ended up with the V112 but had to modify.
