Fishermark
- Oct 19, 2003
- 5,617
I'm helping my dad with his Alpha one. He has had problems for awhile with shifting - especially into reverse. I put a new shift cable assembly on and it works very smoothly with the outdrive off the boat. When I put the outdrive on, the shift cable is very tight - I have to pull the cable very hard to engage reverse.<br /><br />With the outdrive off the shifter on the outdrive (the "foot" or "shoe") turns very easily. I put a new upper shift lever and bushings on, so there is no "slop" in the bell housing area. Everything works great until assembled.
<br /><br />Here is something that I notice that may or may not be causing a problem. With the outdrive off and upright, when I turn the prop counterclockwise to put it into forward gear I notice the "foot" or "shoe" is not pointing straight forward, it is still cocked off to port a couple of degrees. Is it supposed to point directly forward? Is it possible to put this shift lever on incorrectly when assembling the lower unit?<br /><br />If that isn't the problem, where do you suggest I look next?
