I posted about this motor earlier.having carb problems.This is water cooled one cylinder motor.I knew up front that parts would be probally
unavailable.E-mailing Solo USA in Va,although my motor has a decal from same Co&address,has no idea they sold these western German made motors in the 80`s,no parts.
It has 130# comp with 3 pulls,145 with 5.It started up,but I had to pour some gas in spark plug hole,than it ran good in trash can,turned off gas line&let it run dry,and it wouldn`t start next day without pouring in gas again.It has a gas tank on motor,and a hookup for seperate tank.Boy that had it said it got hard to start when last used 6yrs ago.I assumed dirty carb.I now think the fuel pump diaphram got hard.The fuel line goes to fuel pump,but the outside tank line also Y`s into this line.You just turn fuel petcock off to inboard tank to use outside tank.The fuel pump sits right under carb.Then outlet to pump goes up to carb.Since I don`t have the outside tank,and the fuel tank on motor mostly sits above carb(line goes uphill aprox 2",then down a little to fuel inlet on top of carb,but 90% of tank is above carb)I came up with the idea of gravity feed&do away with fuel pump,since gravity should feed carb.The 3HP late model Johnson I
I had 2 yrs ago had this set up,I think.
well,it still won`t start without pouring gas in,and now it seems to starve for gas,like it needed pump,I`d thought a 3/16`s" fuel line would gravity feed it.
I cleaned carb.it has a typical carb with float&2 jets,one in very bottom,I assume this is slow jet.
My problem is,if the bowl gets full,why won`t it start?it shouldn`t need the fuel pumped in under pressure if the bowl is full,should it?Their would be no pressure on carb,if I understand how it works.The pump,or gravity puts gas in carb to float shuts off gas,right?Then as you choke&try to start the vacum of engine copmression sucks gas thru slow speed jet,right?
I don`t know for sure if float is letting enough gas in,float&needle looked good,all passages are clear.
I`ve spent several evenings on this thing,and I`m about to trash it.
Any ideas appreciated?/
regards,Dizz
regards,Dizz
