pinellas50
- Aug 10, 2009
- 207
My boat has very tight steering. 96 Mariner 115 on a 93 Starcraft in case that is important. I unbolted the motor from the cable and the motor moves very freely. So I suspect the cable. The boat is equiped with a single cable rack and pinion. I am now trying to figure out how to get the cable out of the tube.
I have read as much as I can find with the search function. Here is a picture(not mine) of where I am having trouble.
I have my wrenches set up like you see in the pic. When I start unscrewing the cable end, the male threads that go into the female end of the cable are turning with the female end of the cable. It turned like this for a little bit and then everything binded up. I didn't force it because I'm not sure if this is right.
I was assuming you just unscrew the female end of the cable off the male threads and then pull the cable out of the tube. But now I am perplexed after seeing the male threads turning.
Any advice?
Any advice?
