chartersj
- May 14, 2013
- 281
I have been noticing a different sound coming from my motor. It's not overly loud but It kind of sounds like when you blow across the top of a bottle...like a hollow low pitch whistle... hard to describe. I took the outdrive off and still does it. At an idle it sounds like it's coming from the back of the motor or down low and intermittent with the rotation of the crank. Will pick up with some rpms but not always steady. And cruising on plan it comes and goes when I'm adjusting the trim...any thoughts?
