help with suspension fork replacement! DP-A
bransjeep
im in the process of replacing my broken fork, i ordered all the seals i will need to replace and the fork, i started disassembly of the drive and i have the upper gear off, and i dont know if the intermediate needs to be removed from the lower? and if so how does the rest of this come off? ive looked in the manual but it confuses me...so im in need of some help
thanks
Don S
Re: help with suspension fork replacement! DP-A
Yes, you have to remove the complete drive. Are you using the OEM manual?
If so, what part don't you understand? Page numbers help.
bransjeep
the drive is completly removed from the boat and on a stand.. im using the oem manual but it doesnt say if the lower has to be separated from the intermediate to replace the fork
Don S
Look at the manual, How do you think you are going to remove the tube that the fork pivots on without removing the lower unit? (page 82, item 2)
bransjeep
ahhh ok now its much more clear, i overlooked that most likely when i looked the first time
thanks you sir
bransjeep
would you by chance know of a complete seal kit?
Don S
There is no complete seal kit, one for the upper, one for the lower. There are no seals in the intermediate.
