Help with Suzuki year please.
kodibass
Master Chief Petty Officer
I have a Suzuki DT25
2502 F-10126
these are the numbers on the plate & how the appear on the plate, I tried to cifer them on Marineengine.com but cannot figure it out I think maybe a 1985? I want to buy a electric starter as it looks like it once had one in the past & need the year to find starter correct Part# thanks
99yam40
the first 1 in 10126 should indicate a 71,81,91
but the 2502 and the F do not look correct check them again to make sure.
If the F is correct maybe it is a 79 model
where is this motor?or where did it come from?
kodibass
99yam40 I will look again at the numbers & make sure they are correct, The motor is in Kodiak Alaska, I bought it from a local salmon fisherman who said it was his fathers & at one time he had 5 of them just like this one, He gave me a box of extra NOS parts & props etc. He stated this one at one time he believed did have electric start but that was taken off years ago, I tend to agree as it is set up with a rectifier & wiring. The motor is in VG+++ condition runs very well and has 158 compression in both cylinders, I will post a cpl photos of it and the numbers tonight. thanks' Kodi
99yam40
did you click on the link yourself to see if there was anything there?
It show empty when I click on it
jbcurt00
You are posting a link to your photobook account not a specific pix.
Copy and paste the IMG code for the pix you want to post:
Merged the 3 topics into 1
kodibass
Suzuki year+ PC dummy = (photo mess)
Gads''''' sorry guys my computer won't let me post photos the way I used to, But if you look at the old post I did manage to get photo of the number plate posted, Here is I think more. again sorry ' puter idiot x simpleton Mods thank you for your kindness & help I don't mean to make it so difficult. Kodi
99yam40
I have no idea what year it is , it does not match any of the numbers on Brownspoint info I looked at
kodibass
Jbcurt00 if you check my past post you will see I have posted many photos over the last few years, all without any problems, but of late I am unable to use option #1, Which is what I always did in the past, Now I get a pop up that says an "Error has occurred" after I hit upload? My computer?? Iboats?? anyway It appears I'm not the only one who doesn't know how to cipher older Suzuki #s So not to worry this pig is cooked. 99yam40 thanks for given her a shot' kodi
jbcurt00
I suspect the pix are too large and nees to be reduced, resized to fit the new software's perimeters.
This size restriction is mentioned in the pix help link I posted, 700KB, which is small given that even my cell phone will take 5MB pix.
Iboats didnt set the size restriction, the forum software did. When it was updated 18+mo ago from vB 4.xxx to vB5.xxx.xx several other changes occured as well.
Photobucket seems to be working, so I'd suggest sticking w that method for pix
kodibass
Can I ask how you got the year? I think I have a starter motor (Hitachi) that will fit it, but will need new brushes but if the same motor is available on other year Suzukies I might be able to change out the case/gear head. & E-bay has much used as well. thanks\ Kodi
99yam40
79 was the only year the serial # started with a 1 without it being 71,81,91 year and it had the F
But the 2502 does not match up
