I read somewhere that if I were to remove (which I did) the idle control box, little black box beside the fly wheel, that I would have to set the timing, 23deg @ wot. If this is correct, what is the safest way to do this? Should it be in the water or under a load? Its a 1985 merc 2.0 XR2, on the engine stand.
