islander 85
- Jun 12, 2018
- 5
85 islander with an outboard. So I've got the old transom out it was 3 separate pieces bottom where motor mounts and one on eachside of the splash well. It was apparently done before and looks like they took alot of shortcuts. Wasnt sure how it was originally so should it be 3 pcs again or should it be one solid piece? They also put alot of holes in it for I'm assuming for different transducers over the years and only put screws back in the hull with no sealer I know welding them up would be ideal but could say 3m 5200 be an option if I were to put a small plate on the backside sealed with it then fill the holes? I'm planning on installing a stern saver to eliminate adding anyore holes when the job is complete. I am looking at layering 2 sheets of 3/4 marine grade together glue or epoxy? Then sealing with west systems epoxy any better options read alot of posts on here before joining and that seems to be the preferred method correct?
