GMTK
- May 27, 2016
- 164
2004 SX-M. After replacing the bellows today I went for a lake test and my trim gauge is not working correctly. Once the drive is fully trimmed down, the needle on the gauge shoots past "up". Other than that, the gauge seems to be working.
I've read the sticky no less than a dozen times and the PDF by Don. What I can't figure out, under #3 in the adjustment procedures, where do I hook up the ohm meter since the sending unit control nut is already pushed in to the pivot bolt? Do I connect to the wires somewhere else? Maybe I'm making this more complicated than it needs to be.
It's sticky #12 after you click on "volvo penta information"
