How bad am I screwed? Today I tried changing the lower unit oil on my 94 4.3l v6 Volvo penta sx. I drained the oil from the bottom drain plug, and when trying to remove the top side screw plug the head broke off. I tried to drill it out but it went a little Crooked and ate the thread of the housing. It also went through pretty quick and my drill bit punctured a hole a rubber hose that holds water that is behind the housing. Does anybody know where to get the housing that the top side plug screw is. The hose is a standard rubber hose that can be purchased at auto parts. And how complicated is it to reinstall the new housing?
