can u put a gear box from a 70hp on the same engine but it is a 50hp
G godons Cadet Joined Dec 11, 2005 Messages 11 Dec 13, 2005 #1 can u put a gear box from a 70hp on the same engine but it is a 50hp
D dafox99 Petty Officer 1st Class Joined Jul 8, 2005 Messages 203 Dec 13, 2005 #2 Re: help? By "gearbox", do you mean the lower unit? If you could describe exactly what your problem is (including model numbers of engines), some folks here can try to help you.
