help
Fireman29
Guys,
I have a 1995 mariah with the 5.7 350 EFI. I want to change the Oil, however would like to know the weight and brand best to run in the motor.
thanks
chiefalen
Re: help
Sir; may i suggest that you d / l the manual. If you go to the top of the forum " Adults only " you will find a link. Thanks to Don s the manual is free.
This may be a new to you boat, you will find other posts there that you may enjoy reading.
Please do not just put help in the subject. Please read how to post a question.
Good luck !
Re: help
Ayuh,.... Type "Oil" into the iboats Search engine,...
The answer is There to be found...
Pretty much Any oil off the shelf from your local Wally World will work Just Fine,...
Personally,...
I run Mobil 1, 15W-50 in My Boat....
