Re: Help
Welcome to iboats!
The manual for my Uniden Solara says the green wire in the accessory cable connects to the GPS data in and the brown to the GPS ground. In the GPS setup menu, set the following parameters:
Baud rate: 4800
Data bits: 8
Parity: none
Stop bits: 1
RMC, GLL, GGA, GNS, and ZDA Command: used by radio for UTC time, lattitude, and longitude
Perhaps your radio is set up the same way.
