i have 22' mako with a91-94 gt 200johnson, fuel tank 90 gallons when full have chage 2 coil and and all plugs hope to get above 4000 rpm a wot is this the best i will get? book say that 5000 - 6000 rpm is with a should get
If you read the stickies at the top of the page and the helps on the prop store page
it will help you understand prop selection.If you get us the prop size(on the barrel or under the prop nut) make some test runs get us your max rpm and speed we should be able to help.Wouldn't hurt to describe the Mako and estimate the dry weight.
