Help
welcome aboard
I assume you mean 260hp.
what drive is on there?
what is your current prop?
if you have none, you may need to borrow a test prop or two.
my first guess would be a 19P or a 17P as with a 10' beam, thats a big boat.
what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam
Ayuh,..... Welcome Aboard,..... The prop that allows the motor to run in the recommended rpm range, at Wot,......
