First of all still the 1989 Starcraft 3.0 L 181 CID. When I got this boat it was getting too hot at idle with muffs. So I changed the Thermostat. Also decided to pull out drive when i found the bellows to be shot. So changed impeller also. Also the water house too with the bellows. Now all back together. But when left at idle it still gets hot. Not positive what the thermostat should open at. But its the recommended one. I figure by 200 it should open and temp drop. But its not.
Is there another way to check water flow through engine? Noticed a little blue smoke when first running too. But it disappeared after running a short time. So any Ideas?
