I replaced gimbal bearing, u-joints, & u-joint bellows. I checked the alignment & the tool slides in with little difficulty. I fought with this thing today in 90 deg. heat for 3 hrs., then finally gave up in total disgust. I have tried the screwdriver trick, brute force, bumping the engine, etc, etc., got the neighbors pi##ed at me for my language & all of that did no good. I can get it up to the studs, then is stops like I'm hitting a brick wall. Very frustrating. A couple months ago after changing the bellows I had the drive back in & bolted up in 20 minutes. What gives?
