I'll start with the fact that I'm a newbie to the boat build and glasswork world, but I've been doing quite a bit of research and am beginning my first rebuild project.
I was given this fiberglass Herter's Yukon - it's about 15' LOA with a 55" beam. I noticed the boat always seemed to have just a little bit of water in the bottom and have decided that I'm up for some fiberglass work, so here it goes!
The boat will be used mostly for fishing on inland lakes and near short excursions in northern Lake Michigan, and I'd like to have it for years to come - something I'll be able to take my son out on as he grows up.
Here's my gameplan:
First: remove the rotted wood seats and open the bases to get whatever is in there, out. I'm a little curious to see what's in there. Whatever it is, I'm guessing it's pretty waterlogged.
I'm thinking of putting some flotation foam into the bow and 3 underseat compartments (a total of about 18cu ft) - maybe with a combination of chopped up pool noodles and urethane pour foam, then glassing the entire thing in to help prevent even the potential of waterlogging the foam.
I know I'll need to re-glass some areas below the waterline and am planning on using epoxy resin with a 7.5oz glass mat. I've also considered using 1708 glass mat, but am wondering if the CSM layer would be affected by use of epoxy - I understand CSM and epoxy don't mix too well, but I really don't want to get into multiple resins if possible, and I'm not planning to gel-coat the boat.
My paint plans:
I know that's a long way off, but as of now, I'm thinking about using herculiner (gray) for the inside of the boat and painting the outside with a rust-oleum bottom side marine paint. Something like this: https://www.rustoleum.com/product-ca...ifouling-paint - in black.
In the end, I'd like to put a couple of removable raised platforms in for casting - something like this would be ideal:
http://www.listedbypete.com/boat.htm
I'm not planning on doing the whole console thing - just the platform. Thanks Pete (whomever you may be) for that idea.
I'm looking for any advice you may have if you've gone through a similar build. What type of products would be ideal, keeping in mind that I'm not trying to spend a fortune - I know I'll never recoup what i put into the boat, but I'd like to keep my house too.
Is 1708 fiberglass cloth overkill?
I've also considered completely removing the sidewalls of the seats to make it a bit easier for me to re-glass the entire interior of the boat, but is that overkill? Should I just re-glass the soft/cracked spots?
