Hesitation
Josh122593
I have a sport jet 90 in my bayliner jazz.It runs fine until you start getting in it at about half throttle then it bogs down and it will cut off if you dont reduce throttle.What could cause this?
Re: Hesitation
Ayuh,... Donno,... You're in the Wrong forum,... We do I/Os...
I believe the Jet-ski forum offers the Best chances for you....
Don S
Re: Hesitation
Your motor, is a Force outboard powerhead put on top of a jet pump. So I will move this over to the Force outboard forum.
RRitt
Re: Hesitation
sounds like fuel supply. if you burn it up faster than it comes in the the carb bowls run dry and the motor cuts out.
