Hey 3.0 Owners! Freebie!! Quick!!
TwoBallScrewBall
Hi all,<br /><br />I just moved. I'm in the process of putting everything away in my garage. I found the distributor and coil, with new Accell wires, from my 1988 OMC 3.0. I don't need it. Perfect shape, even in a box ready to ship. First person that replies that they need it gets it. The coil, points, cap, rotor and condenser have less than 3 months of run time on them. The distributor (shaft, gear, etc) itself in in perfect shape. I was going to ebay it but decided to do some charity work instead and give it away here. Please only reply if you need it, I'd rather give it to someone that needs it than to someone that wants a spare. OK? This is my small way of saying thank you to all the help I got for all you good people here. <br /><br />PS the reason I have all this is because I installed an EST ignition in my boat last year, and kept the original components. <br /><br /><br />Thanks,
Regal-89
Re: Hey 3.0 Owners! Freebie!! Quick!!
Nice job Stiff(your good deed for the month), I wish I could use them but I have a Mercruiser 3.7(i think-my brain froze). Good luck, but that's cool that your givin em away! Maybe I should do the same with my back to back seats.
notinbig
I have an 88 4.3 are they the same? If so I'll send yo a ups label.
TwoBallScrewBall
Shane, thanks!<br /><br />Notinbig, The 4.3 is a 6 cylinder. The 3.0 is a 4 cylinder. Sorry! <br /><br />This as far as I know will work in just about any year Mercruiser or OMC 2.5L or 3.0L (153ci or 181ci). <br /><br />I'll leave this posted here until it's claimed.
notinbig
sorry I was thinkin about those chrysler 3.0 v6's \<br />my bad, thanks for being friendly.
KaGee
Remember Steve... no good deed goes unpunished!<br /><br /> ;) :D
TwoBallScrewBall
Yeah KeGee that's what I've heard! :) <br /><br />And by the way, that's a great signature. :D
azure
If you still have the parts I could use them. <br /><br />I have a 1972 Larson tri-hull with a 140 Mercruiser.<br /><br />Steve
barrman
I too could use it...can we flip for it ? <br />This is my first boat, it's an 89 searay with a merc cruiser 3.0L that needs a liitle work to get it ready for some family fun.
thomose
Steve,<br /> I do need to replace worn timing parts on my 1987 3.0 OMC. My plan was to go with the standard points, condenser, etc... but now you have me curious as to the electronic conversion. Can you please tell me if your happy with it, was it worth it? Thanks, Tom K.
TwoBallScrewBall
Hi Guys, sorry, haven't checked this in a while. Forgot about it.<br /><br />Stevie and Barrman, whoever emails me their shipping address first, to shuminski (at) gmail (dot) com gets it. Fair? <br /><br />Thomose, If you can get your hands on an EST setup, do it. On my boat, it made the engine run so much smoother. Idle was smoother, startup was quicker, and setting the timing was easier since the timing is electronic and does not bounce around like it does with points. Go for it if you can.<br /><br />Later,
thomose
Thanks for the info. Steve, it sounds like it's the way to go. Is yours the Pertronix setup? Also did you have to do the diode modification to the shift assist? Thanks Tom
TwoBallScrewBall
It was not Pertronix, though I've heard good things about them. <br /><br />It was a Delco EST. Stock on the newer Mercruisers and OMC's. Didn't need the diode. Bypassed the EST completely, wired the distributor "timing shunt" lead directly to the cutout switch as per a mercruiser diagram I found on the net. It momentarily killed the timing advance, causing the engine to stumble. Worked BETTER than the EST module in my poinion. Shifting was super smooth, and easier than it was with the EST module. Actually if you search my posts here you might find some info about it. <br /><br />Good Luck!
seadog2be
I have been looking for a new Elc. dis. for my 3.0. Can you give me a link or place to buy one. All I can find is the conversion kits. my dis is so badly worn this is not an option, thanks. I know auto and boat parts dont mix,,,, however temped to buy one for 151 if it would work for sure. just need boat back on the water.
