FreeBeeTony
- May 15, 2002
- 3,995
A friend of mine told me that the highest point of the heat exchanger must installed above the level of the thermostat. He said something about "vapor lock"? I was thinking of putting together a system of my own with parts from ebay and such. But now I am concerned that I may not know all the "trade secrets". Remember I have an inline 6 Mercruiser 165. I am thinking of installing a heat exchanger from a V8 (as you suggested) to provide better cooling and let the thermostat regulate the temperature. Would the heat exchanger go in the path of the hose that goes from the circulating pump to the thermostat housing? Is it that simple? Or do I have to change the thermostat housing? I am looking at a heat exchanger from a 454, it looks like it has a tank and a "radiator cap" on it. Right now I am thinking of only cooling the block and leaving raw water in the manifold. Any inside information would be appreciated. Thanks....Tony
