I'm starting to plan my wiring for my 1976 26" Cabin Cruiser I just bought. It has a year old 1750 watt inverter in it and the rest is all original wiring, plus all the extra mess that the previous diyer owner put on it. It has shorepower and a very outdated 110/12v converter that powers one outlet, the fridge and hot water heater.<br /><br />I already bought a new Guest 60 amp, two bank charger (for $20.00!!!
) and I want to redo the entire 12 volt system as well as add a couple more 110 options. So my question is, where is the best place to buy ac/dc panels and breakers, as well as other supplies? What would you suggest with the chance to start all over? What would you do and not do? I like the bluewater panels, but not the price!!! Has anyone made their own panels with a plastic or aluminum plate and installed the switches and fuse holders themselves. That is what I'm leaning towards. I like the idea of putting the switches how I want them and being able to install my choice of meters as well. I was thinking of using the tube shaped fuse holders that u can unscrew the cap from outside to check the fuse and mount them next to each switch.<br /><br />Thanks for any suggestions or info in advance.
