Hey Guys Newbie Here Have some Questions??
Bigwayner95
Hey All,
Just bought a "New to Me Boat" Its a 1985 Sea Ray Cuddy 18ft. With a Mercruiser 224 CID 170 with Alpha 1 out-drive. First off let me say boat is great condition for age and use. Now since I'm completely new to the boat world (mind you I do not have a manual, plan on getting one.) Is there anything I need to know as far as faulty equipment on this engine and or out drive... Such things as maintenance etc. and things i should look out for I.E. so i don't get stranded... lol. Now upon or first voyage to the lake. (Mosquito) (warren, Oh) I think I may have blown my stator or regulator, in there any such way to test to see if one or the other is bad? I did test battery with it under load and at the lowest reading it showed 9.9 volts but did fluctuate between 9.9 and 10.9. I went and had the battery tested and its a good battery. Now with out load it read 12volts. which leads me to believe that I may have fried something... I already looked in to doing a alternator and plan on it this winter. Moving on... if my charging system is fried.... Is there any other less expensive kits out there for the alternator swap? I can't see spending over 500 for a system when its just a mount, alternator, and belt? Is there anything out there that can make this engine perform better and faster ? Like tricks of the trade? Like i said I'm new to this world and love it so far! Thanks for all your help!
Wayne
Re: Hey Guys Newbie Here Have some Questions??
Hey All,
Wayne
Ayuh,.... Welcome Aboard Wayne,.... Sure wish you'da stopped by Before that happened,...
Good luck,... yer learnin' curve is 'bout, Straight up steep,...
Check out the Adults Only section at the top of this forum,....
Don has it Packed with alota Great info yer gonna need....
