pjc
- Jun 29, 2003
- 1,856
When you removed the "SB" upper half, you must have had to remove the rubber or plastic insert in the metal trim piece at joint (to access screws). <br />From your photos, this trim looks like that on my Slikker. Were you able to reuse that rubber trim? How did you remove it? Or?<br />If you replaced it with new, gotta source you can advise me to? <br />Thanks,<br />PC_Slikker <br />(thats a trial handle, whatcha think?)
