Donzi zx man
- Jul 7, 2016
- 3
Hello , new to the forum, I actually stumbled across while trying to find solution to my problem, I have a 2002 Donzi 28 ZX it has Mercruiser Bravo 1 outdrives and Mirage Plus with a 23 pitch for props ( twin)
So over the last month or so it has started leaning to the right( driver side) when both outdrives are trimmed down , the only way to correct it and get it to ride level is trim the other outdrive up , but then the handling goes to hell.
The other issue I am having is if I am at a complete stop and hammer down on the throttles the outdrives seem to be reving up and the boat not taking off to keep up, Sometimes when it does that the rpms with just about redline ,where they start beeping , it will churn up a ton of water but not much forward movement , It reminds me of a transmission slipping in a car where its reving up but not moving much ,
When it does this I can back off on it and then go at it again, and it will start moving , But I am having 30ft's smoke me from take off..Had a guy tell me that the props have plugs in them and I should try to put a plug in the back , when I got home I looked and the plugs are there... Any help on this would be amazing as i have owned this boat for a little over a year, has about 42 hours on it and it has been a nightmare , one problem after another. Spent more time in the shop than It has spent at my house
Thank you guys in advanced for any help or suggestions you may be able to give
