You got all the answers man the gauges look great went out the other night hooked the blue up to my dash switch works like a charm. I got a new one not too bad of a problem but dont want it to turn into one. 2002 f50yamaha idling around for about 20 min go to take off and hesitates sometimes a small pop. Is it loading up too rich of a mixture I didnt think it had a idle fuel adjustment. It was missing on the 1st and 4th cylinder cleaned carbs worked great. Also timing belt starts to squeak after about a hour or so of running. is it the tension the motor only has 13 hours so far. Thanks.......
