hey
toonin22
working on a 5hp 4stroke tohatsu 2005. is the compression low on all of these motors or do i need a rebuild. compression was 70. i have heard of some motors running on a low compression just dont know it is one of these. if you have any knowledge of these motors your knowledge would be appreciated.
pvanv
Re: hey
That motor has a decompression feature to make it easier to pull start. Check the specs in your Factory service manual (shows figures for both decompression activated and not activated), and you will probably find that you are OK.
toonin22
Re: hey
question for you. If you were to squirt some oil in the cylinder and then recheck would that show any signs of a problem?
could that be a quick way to check if you do not have manual.
pvanv
Re: hey
That would be standard compression testing technique to determine whether the rings are worn. Yes, you might expect a slightly higher compression with a little oil.
