hi can you help me need info on risers
matthew daley
hi ive got over heating trouble on my omc 4.3 v6 and the risers are badly coroded ive spotted a hole in the exhaust side under neath a allan key blank is it ment to be there as its perfectly round iff so whats it for as its in both risers hope you can help cheers mat:confused:
bruceb58
Re: hi can you help me need info on risers
If your risers are badly corroded, you should replace them. As far as the spot you noticed, you might want to post a picture.
If the boat is used in salt water, those risers don't last more than 5 years.
matthew daley
ok i will but how do you post pics on hear cheers mat
