Its a 2001 150 HP HPDI Z150TLRZ OK i've run it a few times and still can't get the idle to reduce down to 800/900 RPMS from 1400. Can I get a few suggestions on what to look for or check. If i push on the carb linkage i can force it to lower but as soon as i release the linkage it increases back to 1400RPM. I am running it with earmuffs on and the prop on. I've tried carb cleaner but that didn't change anything.
I spoke with someone who says the engine will run rough and only on 4 cylinders till its put in the water (prop needing some resistance) but my ? is should the RPMS be that high? Shouldn't the RPMS drop when it warms up, is this normal when running on earmuffs out of the water?
