irippchainsaws
- Jul 21, 2010
- 1
Im working on a 1988 4.3 liter omc cobra setup... everything looked to be in good condition untill after i started the boat and it wouldnt go into gear. i pulled the outdrive off the fluids look ok and the gears are fine the cable is good but the shift rod thing wont move up or down...so i pulled the prop bearings and one of the gears that would come out trying to get in there where the shifter is jammed and now im stuck is there an easier way? what do you think the prolem is?
