Hiawatha Eska 3.5
tiger 650
Hiawatha eska 3.5 air cooled I have owned it for years. A great running dependable motor. i use 50:1 oil mix. Is that correct? Water is getting in the gearbox. Can i buy new seals for it? What year is it? The only number on the id tag is stamped 10313. The painted numbers are unreadable.<br />I use an Autolite 295 plug.After hours of operation the center electrode is a light brown color.
rickdb1boat
Re: Hiawatha Eska 3.5
tiger 650 <br /><br />I found a few Hiawatha Motors at the site below. None with those numbers though. Check it out. They do have parts for it if you can find the correct Model.<br /><br /> web page
steelespike
My info only goes to 72,3.5 first appeared in<br />69.25:1 ratio in 69/70 was 16:1, ratio in 71 and 72 was 25:1 I dont have any further mix info.<br /> I think the smaller motors may have started using solid state ignition sometime after 72.<br /> My old manual lists Champion J12Y plugs at .o35.<br />Point gap is .020.
