bullsnot
- Aug 22, 2012
- 57
Hey guys I've got an 88 2450 Ciera in fantastic shape with a perfectly working time bomb draggin in the water off the back, for now that is. To counter this I'm looking at doing an OMC to an Alpha 1 Gen 2 conversion but the problem is I'm not sure what gear ratio to put in the new drive.
Currently I have a 5.7L OMC drive with high a altitude gear ratio. (Stamped on a tag on the side as high altitude gear ratio) Since the altitude I boat is anywhere from 4500 to 7000 ft I'd like to stay as close as possible to the current ratio since it seems to be about right.
Where the heck can I find what gear ratio I have? I'm assuming I'd continue to use the same props right? Anything else I've failed to consider?
Thanks in advance.
Thanks in advance.
