I have a carbureted 5.0L G+ Alpha Mercruiser 220 HP 305 cid sterndrive engine. Thunderbolt ignition, ignition timing 10 degrees BTDC. Run at 6000 ft elevation. Stock main jet 1.65 mm changed out to 1.45 mm. Power valve stock jet .90 changed out to .74 Stock gear ratio of 1.62:1 changed out to 1.81:1.
Have two props, three blade 15Dx15P and 4 blade 14.5Dx17D. 15x15 wot rpm = 5300. 14.5x17 wot rpm 4600. Max WOT is supposed to be 4400 to 4800 rpm. Can't get over 32 mph in my 2400 Maxum SCR.
Does the timing need to be advanced? Help!
