I have a high idle (1500 rpm) after a rebuild of my 91 70hp Johnson outboard. I rebuilt the power head with all new components, rebuilt the carbs, and pressure tested the case. It held 8 lbs for over several hours. I was happy until I placed it back on the motor housing and started it for the first time. The engine runs very well except the idle will not go below 1500 rpm. The idle screw is completely backed off and the throttle cable is not holding the carbs off idle. The engine settings were set after the first rebuild, but there was a case leak. I split the case and resealed it and now after the pressure test (as stated no more leaks), the idle will not go below 1500, even with the carbs completed closed. Any suggestions?
