High Idle
JPritch
Boat ran great for me on a 4 day fishing trip ('06 Yamaha F60TLR). There was just one time when I pulled up to a spot, put motor in idle, and it was revving around 2K rpm. I put it back into gear, then back into idle, and it was fine, and never did it again.
Is there something I need to be inspecting/cleaning/tweaking? I assume everything has a cause and things just don't happen as a fluke.
Thanks!
SparkieBoat
Re: High Idle
be sure to check you shift/throttle cables and linkage, make sure nothing is sticking.
robert graham
Re: High Idle
My 2nd on check, clean, lubricate all throttle linkages and cables. Not very good or safe for throttle to stick like that, somebody could get hurt! Good Luck!
robert graham
Re: High Idle
Also not good to throw it in gear at 2000RPM's...could break something very easily!
99yam40
Re: High Idle
Timing being advanced could do this also.
Not sure if your motor has one but make sure the TPS is not hanging up as I think the electronics controls the timing with the input from that maybe
JPritch
Re: High Idle
Wow....appreciate the replies guys. I will definitely check out the items you suggest.
