High Oil Pressure on Mercruiser
sessasails
Was cruising along and warning buzzer sounded off. The Smartgauge and dash gauge said oil pressure was 60#. What should the oil pressure be on a 240 Sundeck with a 5.0 Bravo II (OW344212)? At idle, showing about 30# but at almost 4000 rpm, showing almost 60# with a newer filter and oil change (quicksilver filter). Any idea of cause?
Rick Stephens
Both my year 2000 7.4L powered welding truck and my '07 8.1L pickup run about that with over 100,000 miles and 5-30 Mobile 1 in em. Doesn't sound like a problem to me. My rebuilt '93 4.3L V6 is just under that.
Ayuh,..... Welcome Aboard,....... 10 psi per 1000 rpms is the accepted minimum,..... No problem where yer at,.....
alldodge
You sure smartcraft was showing the error??
Now if it showed 50.7 then there is a sensor problem
Also was it a constant alarm or 2 beeps?
sessasails
Constant beep. The smartgauge would show up to 60.2 with no alarm, but I did not want to push it again to see exactly where the alarm would sound.
alldodge
Don't think its oil pressure
Need to go thru the SC gauge and see what's causing the beep
Here is what causes beeps
QBhoy
Hi. What’s the cooling temp showing ? Other than that being low...I’d suggest the alarm is coming from a different source...like the rpm limiter...low gear oil...
