Re: high oil presure
Hi guys, I'm a retired auto mechanic and have ran into this on car engines in the past, a couple things that will cause it are double gasket on the filter or A stuck pressure relief valve in the oil pump. Heres a little story to go with this, while I was in trade school many moons ago the teacher explained to the class how you could increase oil pump pressure by stretching the spring. I had brought a car to the school to rebuild the engine but that meant it became a class project with many different hands on it. unbeknownst to me one of my classmates decided the oil pump spring should be stretched, well when I got it all together and fired it up..suprise surprise.. it not only blew the rubber ring but it blew the filter apart. Needless to say I wasn't impressed and had to bite my tongue to keep from cursing out loud, I had to lift the engine pull the pan put a new oil pump in and put it all back together. I put another new filter on added oil and this time things went the way they were suppose to...
