wylie catter
- Nov 16, 2010
- 61
Hello everyone. Today I took out my new motor for the first time. It is a 1975 15hp johnson. I recently cleaned the carb, replaced all the fuel lines and installed a new water pump and spark plugs. It idles perfect in the barrel or in the lake but as soon as I opened it up it hesitated then got up to about 3/4 of wot and ran there a few seconds before it died. It would crank right back up on the second pull. I found out that it would run better with the choke on running wide open. But it won't idle good with the choke on. So it would idle perfect with the choke off and when I'd give it gas I would pull the choke out and it would stay running. But it defenetly wasn't running at the full high rpm that it should.
A side note is when I first got this motor running at home I had to adjust the idle adjuster on the outside of it all the way up to get it to sound like it was idling at the correct rpm's. In hind sight that should have told me something wasn't right.
So what does that sound like to you guys?
Thank yall in advance for the help. This place is awesome.
