high rpm slow speed
I have a 115 hp inline 6 cylinder serial#oa732564 mercury 2 stroke.The problem is boat seems to work quit well until I give it more throatle then the engine screams from rpms being so high and boat does not go any faster.Any thoughts to my problem would be much apperiatied.Thank you
usskydvr
Re: high rpm slow speed
Either your prop as too low a pitch or you have spun a hub on the prop.
there's nothing wrong with the prop boat worked fine until sunday.I can spin the prop by hand and feel and hear the drive shaft spin
usskydvr
Unless the spun hub is REALLY BAD ( I have only seen one in 25+ years) you won't be able to test for a spun by hand. There is still too much friction to tell.
starcraft1982
yep.if boat used to go alot faster w/same prop as it has now,youve probably got a spun hub.get her fixed and go boating.
