markwarren66
- Jun 8, 2006
- 14
Hi - <br /><br />I have recently purchased a 2002 Wellcraft 190 with a 4.3 190hp Mercruiser I/O. The tach is reading in the 5500+ range at WOT with a normal load. The boat runs great, however. <br /><br />The boat came with a composite "Piranah" prop on it and an aluminum spare. I'm going to put the aluminum prop on and see if that makes a difference. <br /><br />My question is - since the WOT range for the Merc should be 4400-4800, if I'm indeed 1000 rpm over, shouldn't I notice something else? Don't engines have warning sounds if you're redlining? <br /><br />I don't have the owners manual yet - ordered and waiting for delivery. <br /><br />Could it be a bad tach? Or do you think the composite prop could be the source? The composite prop is a 4 blade 14x22. The aluminum prop is 3 blade 14x19. <br /><br />Thanks
